1986 38-200 fuel tank feed faulty
FrankZ
Hello,
I've had a persistent problem with the fuel tank at about half full not feeding fuel to the engine in rough seas, especially on a starboard tack. The engine will quit as if out of fuel, when I know I've got 20 gallons or so left. Once the boat levels out, I can restart the engine. When I refuel, approximately 25 gallons will fill the tank. It's a 59 gallon tank (aluminum and I don't think it was swaped out for a smaller tank), so there should have been plenty of fuel in the tank when the engine failed. Has anyone had the same problem. Does the syphon line or feed line in the tank only go about halfway down into the tank? Any help would be appreciated.
Frank Z.
hodo
hi Frank, the first thing I would do is make sure your vent system is clear. you also might want to make sure the fuel line is hooked up to the correct port. I recall one a few years ago with a similar problem, and it turned out some one had swapped the fuel supply with the reurn fitting on the tank. Turns out some times they put a tail pipe on the return so it doesn't create foaming and the tube went down about half way into the tank. good luck, let us know...... Harold S/V mischief :devil: Maker
