I'm planning to replace what I think is my boat's original boom topping lift (the in-boom portion and the wire topping lift).
Here are the specs from the Manual for the in-boom line and for the lift line wire, and a pic of the in-boom line cleated on the boom, and the wire-to-wire connection at the end of the boom.
Although it's not in the specs in the Manual, it looks like I probably have a wire-rope splice inside the boom ... can anyone confirm this?
I'll use a mouse line to pull the in-boom line out, but before I do that, I'd like to know what I'll find: e.g., if the in-boom wire passes over a block, that block will likely be metal, and narrower than any block that the 3/8" line will use - so, I'd need to plan accordingly for the diam of the mouse line I'd want to use.
