Amontyg
I’m gearing up to do some spring maintenance on Misty and one of the things I was planning on getting around to is installing the more robust alternator bracket on my M25 engine. After taking a look at my specific engine and comparing to the photos of others retrofits it seems mine is a bit different. Rather than having the alternator bolted to a single point on the case it has a supporting bracket on the front which ties it to four other points. This configuration does seem more robust than the other failure prone configurations I’ve seen photos of. Does anyone know if this configuration shares the failure rate of the single mount point design? I’d rather not tear into this thing if I don’t have to.
