Old Newbie
Happy St. Paddy's Day all. Spent mine doing boat maintenance.
Changed the belts on my Yanmar 3GM30F today. Purchased the boat last March, and I have no idea when the previous owner last changed them. They were fine last season, but I wanted new ones. Took the old ones off, cleaned rust from the pulley wheels, and put on the new belts. Neither the water pump pulley or the alternator pulley were able to be put back in the exact position they were in with the older belts, so wanted to see if this is a problem.
The water pump at least got very close to where it was under the old belt, but the alternator is nowhere near the same slot, and I cannot get it to budge any higher with the new belt attached. Could barely even get the new belt attached, but finally stretched it enough to fit. I’ve attached some photos showing what I mean. Also, the older belt set inside the pulley wheels much deeper than the newer ones, even though it is the exact same model belt. Hoping that's just what happens with normal wear and tear.
Do I have a problem here, or is this just the way it works with new belts? And if I do have a problem, how in the hell do I get that alternator to slide back up to the same position with the new belt attached? As always, thanks in advance.
Old belt attached.
Old belt alternator position
New belt attached
Alternator position with new belt attached
Old belt attached.
New belt attached
