Aluminum Radar Pole FS
Pix are in my recent blog entry. All you would need to do is cut an oblong hole in the upper part of the transom slope of your Olson 34, and glass in a short socket frp tube to the hull/bottom.
The angle is 37.6 degrees from vertical for the thru-transom plate so you can check to see if it might match the transom angle of your 80's E-boat.
Also, that plate can be pretty easily cut off and re-welded to a different angle.
Note that shipping is relatively expensive, so best to arrange pickup in Portland.
Price is totally negotiable, as the potential buyer list is... microscopic.
In-use picture here: https://ericsonyachts.org/ie/media/o-34-aug-14.15571/
Hmmm.... I was hoping for more than "about $10." estimated scrap value. :)
And another EY owner has tentatively offered me twice that much, and is supposed to pick it up soon.
So, it may be 'sold'.
I will amend this ad if it does leave.
Thanks for asking!
67rway
No problem. Hope you get it sold.
Sad not to be able to check out the progress on Fresh Air these days...
