Barient 2 speed 21ST issues?
RobG
One of my concerns noted in my survey was play in the drums of the genny winches. I could grab the drum and rock it on the the shaft. The same for both winches. They (as with the rest of the winches) are pretty gummed up so it is hard to tell how this would affect their performance. Deducting the replacement cost from my offer would, I think, be just too much since I already have several necessary ones in the works.
This play is not normal - correct?
How much play is OK, how much is a concern?
Thanks in advance.
<!-- / message -->
Emerald
They shouldn't be loose, but a tiny wiggle is probably OK normal wear and tear. The good news is that you can probably rebuild them. If some of them are gummy and not loose, you probably just need to strip them down, clean/relube and then make a call on wear. Check out this link for a source of parts:
http://www.arco-winches.com/products/spares
