There is nothing wrong with any of the multitude of battery types available for marine use. Everyone will have their preference for the managing electrical loads. The trick is to match the battery type with the conditions and intentions of use.
Flooded lead-acid batteries have been around since 1859, so they have that going for them. Oxygen and hydrogen are byproducts when charging which is what happens to the sulphuric acid when it evaporates, thus the recommendation to add water. This is part of the reason these batteries are meant (required by ABYC) to be kept in a covered container (battery box) vented to the atmosphere.
H and O can explode if sparked, rapid gas producing charge rates are discouraged. A good rule of thumb for L/A batteries is to limit charging amperage to 25-30% of the AH rating to limit off-gassing. The other reason to box the battery is to contain the Sulphuric Acid in case of a spill. A good charger or solar controller will be programmable to operate within the limits of the battery type selected.
(Other lead batteries like AGM and Gel are "starved" of acid and are valve regulated which is why you can install them in just about any position, even sideways, although they won't cycle as many times as a properly maintained Flooded Lead Acid.)
Adding water maintains the magic chemistry that makes electricity. What you're really doing is diluting the specific gravity of the Sulphuric Acid from about 1.84 to 1.265 for a "fully charged" battery. Remember those squeeze bulb hydrometers in your grandfather's garage? It'll go far toward an honest assessment of battery condition. If all your cells (six on a 12v battery) are the same specific gravity the battery is in good health.
An inexpensive and more accurate refractometer is an improvement over the hydrometer and available from Jeff Bezos. Distilled water is a really good idea when maintaining specific gravity and readily available at your local supermarket (at least around here).
Over discharging and/or a partial state of charge of Flooded Lead-Acid batteries causes the lead sulphide plates to build up a plaque (crystalline) of sulfates. This inhibits the production of the ions that make the magic happen. If a cell or cells become more sulfated than the other cells you'll get a different specific gravities and an unhealthy battery on its way out. This is a bit like good dental hygiene, avoid plaque, or add water to adjust specific gravity.
Some chargers will periodically and intentionally overcharge the Flooded Lead-Acid battery to recondition the lead plates from sulfation. This "stage" of charging is called Equalization and should not be applied to other battery types. Returning the batteries to full charge after use should make this stage largely unnecessary.
Voltage as a measured rate of charge is a snapshot in time and not a super accurate measure of overall charge level. You'd have to "rest" the battery for 24 hours to get a more accurate state of charge reading. Battery monitors are more accurate as they measure over time, but sometimes a snapshot is all you really need. There is also a "threshold level" beyond which appliances (like lightbulbs) become less than useful, usually about the time you need them most, or 11.9 V, whichever is greater. (Remember the dimming light of those late hours reading by flashlight under the covers? Threshold level...)
Don't overcharge, don't over-discharge, avoid partial state of charge, return to full charge after use, trickle charge when in storage, maintain your specific gravity and you'll get years, and years, and years, and years of reliable use from Flooded Lead-Acid. Can't be bothered? Choose another battery type or knock off a few of those years.
Oh, by the way, that thing about not storing batteries on concrete is a myth. Might have been true in 1859 when the boxes were made from wood but we've come a long way since then.
