My old Xantrex charger has failed (display does odd things; still charges (at dock; not from engine) but I am not clear it would stop -- does not look like it will go to 'float' anymore.
Anyway, time for a new one. The person who might do the work has suggested:
- Victron charger
- Combining my two house batteries into a single bank, and adding a smaller 'start' battery (that does not power the house circuit, just the engine.)
Does this sound sensible? He says that running the two batteries together as a single house bank will allow one to get more power out of them, since the current draw will only be half from each. That actually makes sense to me, given that rapid discharge does decrease the power one can get out. But "makes sense" and "is right" are different things
Anyway, seems like if I have a separate start battery, I don't really need to do the old 1/2/both/off system for the two full-size batteries I have.
Also, is Victron a good way to go?
Any advice appreciated! (including about anything else I should be cognizant of here / need to think about when replacing the battery charger / battery connections.)
PS: I was thinking I might add a galvanic isolator in the process.
- Victron charger
