bilge shower pump, E38 from 1987
buongiorno, chiedo informazioni pompa di sentina, dove scarica? Devo ripristinare I cavi sono scollegati, quali colori e dove vanno? Come connettersi, grazie mille. Saluti. Saverio
Buongiorno, Securmar. I suggest you use Google translator, since few of us speak Italian.
(Ti suggerisco di utilizzare il traduttore di Google, poiché pochi di noi parlano italiano. }
good morning, I ask for bilge pump information, where does it discharge? Do I have to restore The cables are disconnected, which colors and where are they going? How to connect, thank you very much. Greetings. Saverio
Greetings, Saverio.
What model of 1987 Ericson do you have? If the toilet is next to the ladder (the stairway), it is Model 38-200. If the the toilet is near the front of the boat, it is Model 381. The bilge plumbing may be a little different.
Download of the Ericson 38-200 manual: https://ericsonyachts.org/ie/resources/e38-200-owners-manual-stnd.118/
Some information about the Ericson 381: https://ericsonyachts.org/ie/resources/e381-misc-info-pack-includes-drawings.129/
Blueprints for the Ericson 381: https://ericsonyachts.org/ie/threads/ericson-381-factory-diagrams-complete-1982.17143/
1911tex
Saverio: It should be very obvious to you that these Ericson folks are a very experienced rare breed of sailors that will bend over backwards to help. There is also a "search" button top right corner. I am relatively new here also and cannot believe the amount of experience within this forum. Good Luck !!!
[QUOTE = "Christian Williams, post: 131651, membro: 7704"]
Saluti, Saverio.
Che modello di Ericson del 1987 hai? Se la toilette si trova accanto alla scala (la scala), è il modello 38-200. Se la toilette si trova vicino alla parte anteriore della barca, è il modello 381. L'impianto idraulico di sentina potrebbe essere leggermente diverso.
Scarica il manuale di Ericson 38-200: https://ericsonyachts.org/ie/resources/e38-200-owners-manual-stnd.118/
Alcune informazioni sul Ericson 381: https://ericsonyachts.org/ie/resources/e381-misc-info-pack-includes-drawings.129/
Modelli per l'Ericson 381: https://ericsonyachts.org/ie/threads/ericson-381-factory-diagrams-complete-1982.17143/
[/CITAZIONE]
Grazie Cristian
Ho scaricato il file di download manuale di Ericson 38-200: https://ericsonyachts.org/ie/resources/e38-200-owners-manual-stnd.118/. Vorrei tradurlo in italiano, non posso evidenziare il testo, non mi dà la possibilità, non posso copiare / incollare sul traduttore di Google, esiste un altro sistema? Grazie mille. Saverio
(I downloaded the Ericson 38-200 manual download file: https://ericsonyachts.org/ie/resources/e38-200-owners-manual-stnd.118/. I would like to translate it into Italian, I cannot highlight the text, it does not give me the possibility, I cannot copy / paste on the Google translator, is there another system? Thanks so much. Saverio )
Suggerisco di trovare un amico che parla inglese per aiutarti.
(I suggest finding an English-speaking friend to help you.)
