EricFox
Has anyone suffered corrosion at the base of their binnacle? There appears to be a fracture that has allowed for water ingress. Given the limited extent I'm not concerned about weakness (though it is getting close to the one bolt - may need to drill a new hole a few cm to the right), but I do want to prevent it from getting worse. I'm thinking of grinding with a dremel tool down to good metal, then fill with resin, then paint. Does anyone know what metal the binnacle is made from?
