Surveyed an E38-200 yesterday and found the binnacle felt less solid than I’d like. It moves forward/aft and seems to flex the cockpit sole at the base. No obvious signs of water intrusion from soundings or meter readings of entire cockpit sole. Underside of sole sole looks clean as well. With me pushing on pedestal guard and surveyor below he said he saw the backing plate assembly moving as the sole flexed.
Only thing I can think of is that the backing plate seems small relative to the base it supports, but I’ve seen pics on this site of the same backing plate and haven’t heard mention of a similar concern. Also not sure it could be made much larger at the forward end before coming up against the lip of the raised portion of the sole.
Has anyone out there dealt with a similar situation? If so I’d love to hear your thoughts on causes / remedies. Thanks!
A few pics attached but unfortunately no good video showing what I’m talking about. I need to learn to be a better videographer.
