Second Star
On the 28+ the inlet and outlet are port and stbd, right aft on the outboard side of the cockpit combing. They were originally removable "scoops" with a screw in plug (like a fuel deck plate only about 3 inches across) if you weren't using the system. I have replaced the broken scoops and missing plugs with vent covers. The blower is located aft stbd mounted on the inside of the transom and a removable panel provides access to the blower. As above, there are two original power switches, one big turn switch on the main panel and one simple switch on the engine panel, although they are 3 way switches so don't have to be "aligned" to function. I raised the exhaust hose to above the engine with a metal home furnace vent piece of ducting to remove hot air from the compartment for the reason many have stated above - this also lowers the temp on the inboard side of the icebox.
WRT the vent covers that replaced the scoops and waterproofing plugs I must say that a couple of knockdowns have concerned me about the high potential of flooding in through the vents! I am designing a way to run the vents horizontally directly inboard along the inside of the transom to midships with a trunking hose that could take the weight of water in them. I think this will act as a a kind of schnorkel or stand pipe to prevent flooding when extremely healed over. Anyone else done something similar?
