My boat partner and I have a 83' 35-3 with a Universal M30 engine. While doing a routine check on the HX zinc, we noticed a deep dent on the HX. The dent was about 1/8" deep and touching the mounting bolt of the HX bracket. It must have been caused by the bolt digging into the HX with all the engine vibration - installer's error (guilty as charged). Good thing the dent did not go through the HX. We removed the HX and patched it up with JB MarineWeld epoxy from Home Depot. That seemed to do the trick to repair the HX dent.
After removing the HX, we found another cause of the problem. Our HX bracket was broken and not offering stable support to the HX (see photos), causing more vibration. I've been looking all around the web to find a replacement bracket, but no body seems to sell that part. If anyone knows where I can buy this part from or knows of a workaround for this problem, please let me know.
Another challenge in this repair job is the bracket mounting bolts. They are super seized and would not budge. I guess I'll just have to do that dance (heat, lube, force, repeat) with them until they come off.
