It may be a dumb question, but are you sure it's the tie rod end? There's a compartment aft of that on the other side of the bulkhead that's accessible by removing a panel in the floor of the locker. There may be something in there that's rattling around.
The reason I'm asking is there's almost no way this tie rod end would be loose if your rig is properly tensioned as it is the termination point for the aft lowers. Something has to be holding tension in the rig. If your deck isn't bowed up, there's almost nothing holding tension.
If you've done the rig check and still need to tighten this, you're going to need a good penetrating lubricant. CRC's freeze off worked well for me. Make sure you have a really good adjustable wrench so you don't round off the flat spot on the tie rod. Once you have is spinning, take all tension off you aft lower shrouds, tighten the rod so it just makes contact with the U-Bolt backing plat and the pin is seated in the TAFG, then tighten the rod one more full turn. This is what Ericson recommends and it seemed to be right for me.
Nothing in the aft compartment and nothing else is knocking. Where the rod terminates (pics attached) is moving/rotating left and right. It’s the only one that’s loose. It moves independently of the tie rod which doesn’t move at all. Thanks for the quick response.It may be a dumb question, but are you sure it's the tie rod end? There's a compartment aft of that on the other side of the bulkhead that's accessible by removing a panel in the floor of the locker. There may be something in there that's rattling around.
