ky ed
Extreme Adventurer. E27 trailer sailor from Iowa
As we all know, the e-27 has a deep sump in trailing edge of her keel. Im in the process of changing out bilge pump hoses. Mine were old, brittle and smooth inside with vinal coil reinforcement and corrugated exterior and some were of spa flex type glued to sch40 pvc fittings. Not seaworthy at all! I have upgraded to 491 type of hose. I have a largish pump with 1 1/8" hose im raising up from bottom of sump and installing a small pump on floor of sump with 3/4" hose My problem is i need check valves to prevent short cycling of bilge pumps because of longish runs of hose draining back into skinny narrow deep bilge. I need a real good leak free check valves. I am aware of no check valves in bilge pump recommendations. Any recommendations to avoid check valves would be greatly appreciated. Who makes the best check valves? I also considered vented loops installed high on the inside of sink cupboard to prevent siphon effect of long run to transom but drain back from vented loop still fills sump to near the point of activating pump. What have others done to address this problem? Thanks so much. This group is the best ever!
