This may be a dumb question, and I guarantee it won’t be as interesting as the great clevis controversy of ’23 (https://ericsonyachts.org/ie/threads/the-clevis-pin-controversy.20861/). Diameter is obvious, but I can’t seem to find anything about the grip of a clevis pin. I ordered new toggles with the chain plate u-bolts from Garhauer. They are a little too wide for 7/8 but not wide enough for a 1” grip pin and I can’t seem to find 15/16 outside of RigRite. When I asked Garhauer, they said, “I don’t think the longer ones would hurt anything”. Seems like a reasonable answer, but is there a standard out there? All the pins I’ve seen on Jaw style turnbuckles come with pins that set the cotter pin right on the face of the jaw. Not too tight and not too loose. I found the same problem with the below deck port side lower tie rod chain plates. Has anyone else run into this problem?
