Compass Bubble Fill
This Ritchie (Danforth) 5" Constellation was sent to Viking for refurbishing about two years ago. Viking replaces the card, lens, diaphragm and fluid for about $250. Recently it developed this bubble.
I have a hunch there's a leak in the diaphragm. But in the meantime, it's a five-minute job to remove the bubble by adding fluid. Good idea to put the compass and fluid in the fridge overnight for max density.
What fluid? C'mon! Ritchie Compass Fluid. Why guess?
I happened to have an epoxy syringe, but a turkey baster works too.
It takes a few tries "burping" the dome before all the bubbles are out.
The key to a full dome is the diaphragm, which expands and contracts as temperature changes. Rubber gets old, so periodic replacement is necessary. That's easy: http://www.ericsonyachts.org/infoexchange/entry.php?122-Ritchie-Diaphragm-Replacement
We'll see how long this one stays full.
Rocinante33
Christian,
That was a very timely post as I have developed a bubble. I will see what I can get done applying this sound advice.
10/20/20. Bubble is back. Size of a button. Doesn't seem to matter and may be dependent on temperature.
I had a leak/air bubble in mine, too. Leak was from the fill screw, not the diaphragm. No leaks since refill 2 years ago. I remove the compass every winter and store it indoors.
Tin Kicker
Don't know if it will still work, but they used to be filled with good ol' kerosene or mineral oil.
What type of fluid is in my Ritchie Magnetic Compass?
Until 2001, all Ritchie compasses (see exception) were filled with Odorless Mineral Spirits (100% Paraffin based). Ritchie now uses a fluid called Isopar L that has similar properties but some added benefits over Odorless Mineral Spirits.
Exception: Some old style Flat Top Compasses used a mix of denatured alcohol and water. This process was stopped in the 1960s. If you have a Flat Top Compass, it is recommended that you test the fluid to see if it is Odorless Mineral Spirits or an alcohol/water mix
Ed Valente
When I replaced the dome on mine about two years ago, I used this bottle I found at a local science surplus store for the refill. The volume expedited the process. So far I’ve had no issues (at least involving the compass).
