Nice power plant and configuration! ... appreciate the pics! I've a bit more room for a mtg.s spot.If you study this blog entry photo, and the other entry next to it, note that we used a new tank from an auto-supply store. Key thing was to mount it so that it was just above the plane of the hose exit from from the pressure cap. This has been operating OK since 2018.
O34 - Wiring & Engine Detail, part 2
These photos show the Halon bottle in place, and also a much better look at the inside of the compartment where the meter and terminal strip are mounted. As an "extra" there is a shot of the new coolant overflow tank showing how the level in it...ericsonyachts.org
If the radiator cap is where you have been checking and adding coolant, then yes. With a working recovery tank installation, coolant will be added in the recovery tank instead of the radiator cap. In fact removal of the radiator cap will commonly result in spilled fluid. Level of tank is not real critical: it can be a few inches higher or lower.Coolant tank: So level of tank just above Radiator cap ?
Having a hard time identifying the correct fuel fittings for this pump, "476459 E" literature says 5/16" in one place, 1/8 inch in others. I've measured ID on pump fittings, 3/8"... ???I have a 12V Facet "Cube" on my M25. Not long ago, as I was heading out for a sail, I discovered that increasing the throttle would only get the engine speed up to 1800 rpm and not more. It turns out that my electric fuel pump had failed. Now, whenever I go to start the engine, I listen for the distinct rapid clicking sound of that pump before energizing the starter motor. And I will start the Spring season with a spare pump.
That's a big difference in values. Looks to me like the pump has 1/8" female pipe thread openings and it is available with 1/8" MPT x 5/16" barb fittings for connection to rubber fuel hoses. Maybe post links to the conflicting sources if this doesn't help.literature says 5/16" in one place, 1/8 inch in others
For those challenged in ciphering pipe, we don't normally refer to thread count for common pipe fittings like we do for bolts. while bolts are available in NC or NF (National Coarse and National Fine, respectively), common pipe fittings only have one thread spec for each pipe size. But be careful not to confuse or mix common "tapered" pipe thread fittings with straight pipe threads. The latter are commonly found in fixtures, like faucet connections, and in specialty fittings like the grey "Qest" fittings in the water piping systems originally installed in many of our boats. Whenever you see NPT, MPT or FPT (National, Male, and Female Pipe Thread, respectively), that should always refer only to common tapered pipe fittings. Unlike for tubing, pipe measured sizes have little correlation with "nominal" or designated pipe size, but a table like this one can be useful in deciphering. Be sure to use a couple of wraps of teflon tape on the male threads of fittings to assure a leak-free installation.1/8"-27, NPT
