Yesterday I had our E32-3 pulled out to do bottom work (paint and polish) along with other things that required to boat to be on the hard. After the Chesapeake slime was power washed off the old bottom black paint look very good considering it was applied two years ago. There were also a few small blisters but no big deal. So, I left the boat in the good hands of the marina to be blocked and worked on.
However, later after the hull dried out a bit I received an email from the service manager which read in part, "We have a concern with the rudder and the strut. Both are moving a bit more than then should and they are weeping water. There are cracks outlining your rudder shaft. It looks like you need a new rudder bearing." He also included some photos which I marked up for clarity.
Here, on the port side, you can clearly see cracks in the areas before and after the rudder post. The service manager said that after most of the hull dried out from the power washing a little water was seeping out of these cracks. Also the rudder was shaking too much, from side to side, and he thought I would need new rudder bearings.
Here is the view from the starboard side where there are some additional cracks similar to those on the port side.
Looking from below up at the hull cracks on the port side and a shorter crack at the bottom.
Top of the strut. The service manager said that the strut was too loose and again some water was dripping out of the connection area and bottom paint was flaked off.
WHAT TO DO NEXT?
The next step is to drop the rudder to get a good look at the bearings and the rudder tube. Dremel the cracks to see if they could just be fairing material that is cracked or if the cracks penetrate much deeper. Then find access to the strut nuts which on my E32-3 are (I think) below the hot water heater and the platform that it sits on. I've never even seen those nuts so I'm not sure if they are accessible for tightening. If they are then the strut would still need to be removed for inspection and re-bedding.
WHAT I'M HOPING FOR IN THE END
As far as the cracks around the rudder tube area I'm thinking that this is solid fiberglass. Perhaps someone who's had experience with repairs in this area can tell me but considering the hydrodynamic loads on the tube and rudder shaft I'm guessing that it's solid. (I could be wrong) The same goes for the strut connection area. I've not had any large volumes of water in the bilge, just some when it rains a certain way, but none after a "lively" sail which IMHO would be the case if the cracks penetrated through the hull at the rudder tube. If not heard (aside from a small creak now and then) or felt anything in the rudder while sailing. I'm hoping that it's just cracks in the faring through that area and it can be easily repaired and not cracks that go much deeper requiring the whole area to be rebuilt which would be rather expensive.
As for the rudder bearing repairs, I did do a little bit of research on this site about that issue and discovered that the E32-3 (1987) has two rudder bearings. One at the top which is replaceable and the other at the bottom, glassed in the the boat (????) that is not replaceable? But repairs have been done by previous owners using a technique developed by West Systems that is described in their Fiberglass Repair Manual (Section 8.4). https://www.westsystem.com/app/uploads/2022/10/Fiberglass-Manual-2015.pdf
COSTS
This is a big one, of course. The service manager stated that I had a very good boat and, besides the current issues, it's in great shape. A very recent insurance marine survey also echoed his sentiments. However, it comes down to how much I'd want to spend. That amount is unknown at the present and we'll only have a better idea of the potential costs after some "exploratory surgery" is done. Then it becomes a personal issue. If it's too high then, as the service manger suggests, donate the boat and then look for a new one. But starting over again even with another Ericson for example would require additional expanse to bring it up to the upgraded status of my current boat (new electronics, standing rigging, sails, etc.) Buying a new boat requires a large expense up front. Spending the money for the worst case repairs may actually be the most economical way to go. All questions to consider but first we need to diagnose the full extent of the problems. Stay tunes, as they use to say.
WHAT TO DO NEXT?
COSTS
