After finally refinishing the aft cabin bulkhead(s), around the hanging locker, I was propping up the new charger and about to drill four holes to attach it, and a couple more larger ones for leading the AC cable and the three DC wires. And... the new temp sensor wire. Lots of hard-to-ignore holes.
Before unlimbering the drill, today we got to pondering whether it might be best to (figuratively) step back a ways and be sure that we still have the best compromise for a charger location. Kind of like refocusing on the forest, rather than seeing just one or two trees, as it were.
Background: the EY factory location for a charger on our O-34, was to attach it to the backside of the port side aft hanging locker, accessible , very awkwardly, from under the cockpit seat. After taking delivery, I had to replace the ancient OEM ferroresonant charger that had ruined the original batteries.
This was after buying the boat in 1994. After removing the old charger, I then found a different location for the new Xantrex solid state charger, on the rear side of the bulkhead that is beside the gallery range. i.e. just inside the aft cabin. inconspicuous and yet easy to get at when needed. That charger had to replaced back in 2010, and the ProMariner replacement had been working fine until a couple months ago.
The new one, a new-generation Promariner 20 amp charger, has a different size and wider footprint and would have to mount on the adjacent face of the aft cabin hanging locker. This is visually sorta-kinda OK with us, but before drilling any new holes in the teak today, I got to scoping out the path for rerouting the cabling, and that lead to wondering if it might be prudent to reconsider the whole location. Perhaps.
It would be easier to run shorter cables (both AC and DC) if this new one could live on the port side of the cabin, under the aft overhang of the chart table top. I recall seeing pix on this site of 80's Ericson's with a new charger in the "knee well area" on their model and recall comments that it was not too intrusive on Viking knees when seated at the Nav Desk.
Such a location would guarantee the vital air flow the charger requires, as well.
If you have experiences and wisdom to share, please do so!
I will try to add some photos tomorrow or so - of the area(s) in question.
Thanks Much!
Thanks Much!
