    EY.o April Zoom Meeting
Door in Settee back
Jim Picerno
1989 38-200
At some point I need to inspect the tie rods which will require removing the bungs and screws from the settee backs. I was wondering if anyone has put a door in the settee backs? If you did could you post a photo? Thanks.
I have not created an "opening", but several decades ago I did remove both of the teak (veneer) backs. I removed the factory plugs and then the screws. At the time I was bleaching and varnishing the teak.
I recall the thought process that since those panels are normally covered (94%) by the cushion backs, there was never a reason to put plugs over those ss screws in the first place.
Lucky me, no prior deck seeps or leaks had ever caused a corrosion problem where the big ol' Navtec rods were threaded into pieces of aluminum round bar. It was a relief to confirm the present condition and to admire the strong FRP engineering that anchored the high shroud loads. It further confirmed our decision to buy an EY-constructed boat. :)
Further, you might find that creating a third opening, similar to the sizing of the present two, will satisfy you need for inspection and no door/cover will be needed.
Jim Picerno
1989 38-200
Thanks Loren for your response. Creating a third opening is a good idea. Inspection of the tie rods is one reason for my request, but I seem to recall one of Christian's videos where he was storing tools in cupboards behind the settee. His boat, is an earlier model with a slightly different layout, but it would be nice to utilize that space for storage if it were possible.
Looks like you already have two openings, so adding another would blend right in?
My boat was is a bit different, with a fiberglass liner covering everything. I eventually had to cut lots of holes to access hardware, but yes, I did put doors in the settee backs. https://ericsonyachts.org/ie/ubs/small-aliquots-of-progress-stbd-side-stowage-part-1.639/
23728.attach
I messed them up a bit by first making them with a friction latch and finger pulls cut along the opening edge, then changing my mind and adding push-button latches. I also made them perhaps heavier than strictly necessary because I figured they could get a lot of weight applied to them.
Eventually I made simple box cushions to hang on them, instead of a large more standard back rest. The hanging loops haven't worked out too well - doors won't close properly. Will switch to velcro one of these days. Or the next owner will. The cushions get used almost more as throw-pillows than as back rests.
img_3201-jpeg.40410
If I did it again, I would radius all of the corners. I guess it seemed like too much of a technical challenge at the time, but it's really not that hard.
This month I've finally arrived at the point where, for similar reasons, I have to cut an access port into the deck of my new boat! I'll install a pre-made deck plate and make it into a hawse for the stern anchor rode. Which reminds me that I did originally put a couple of screw-in deck plates in Arcturus' settee backs, b/c I thought they might be water tight compartments. But they are not.
