A friend (with a Catalina 42) has a very handy dual-Racor system in his (comparatively huge) engine compartment. Picture below.
When his engine stared to back one time on the water, he just went down and flipped the vale lever, while the engine was running, and had a fresh clean Racor in line, engine started working fine, and he had plenty of time to replace the clogged one. [The pressure gauge allows one to tell how much resistance the filter is giving -- how clean it is.]
I want to do this, since when I need the engine I am (around here) most likely trying to avoid a huge ship or in a narrow channel. No time to mess with fixing the filter under pressure even in calm water. And the only engine failure I've had was due to air in the line from an incorrectly installed filter (not by me -- I had just bought the boat. But I am completely capable of messing that up...)
So:
1. Does anyone here have something like this installed?
2. My E34 engine compartment is tiny. This thing doesn't fit in there. I was thinking of relocating it to above the forward-bulkhead/shelf in the stern berth (a berth which I do not use except for storage, and is right on the other side of the engine compartment.)
--> Is that a bad idea?
[In the engine compartment, a leak goes into the bilge. In the stern berth, into the... berth. I am not sure which is worse, really.]
3. I have heard some Racors have pumps on them to fill them up with fuel after you replace the filter, thus avoiding all the "fill it up while boat rocks back and forth and you try to avoid the hot engine parts with your body" fun.
--> Do any of you have these? What model is it? Advice?
Many thanks!
Image of the system I'm talking about:
PS: These threads are relevant but don't address the dual-racor or pump-top racor questions... I chose to start a new thread.
@Prairie Schooner comments on something like this, only using different filters:
" I suppose in place of the engine mounted filter someone could also just install a second Racor. That would give more flexibility in choosing micron level for the filtration."
ericsonyachts.org
and @vanilladuck has a long discussion of racor replacement here:
ericsonyachts.org
So:
Many thanks!
Installing a new Racor 500 on an E32
The brown rusty stuff is likely diesel fuel algae/bacteria sludge. You'll probably want to check the tank. I believe it grows as a result of water getting in the fuel. As far as getting water in the fuel, this is probably as good a time as any to mention that changing the O-ring on the fuel...
E32-3 - Fuel System Refit with a Racor 500
Intro When I started thinking about the fuel system on Rumour, I realized there were a few things to consider. I heard a number of recommendations to remove the old metal fuel supply lines and check or replace the old Racor 200 series primary...
