klb67pgh
I’ve been building my winter to-do list for my E25 I acquired in August and will haul out this weekend, and could use some guidance.
Stanchion, bow pulpit, and stern rail feet to upright attachments:
My stanchions, bow pulpit, and stern rail have stand-alone feet, and the uprights are attached with a single stainless screw (I assume this is factory?). The feet are well bedded, some with backing plates, and do not flex, but there is slop in the joint between the feet and the uprights in most locations. I replaced several of the screws with new screws with cleaner threads that tightened up the joints a bit, but not completely. I don’t like the wiggle, and would like to address the slop. As I see it, I should either get someone to weld the joint, or I should drill and add another fastener, perhaps an allen set screw, installed 90 degrees from the existing screw. Or try replacing the stainless screw with a stainless rivet. Thoughts? Other solutions?
Back stay removal:
Attached is a picture of the attachment between the back stay and the split adjustable back stay. I acquired and intend to add a 2 bow bimini mounted on the stern rail. The back stay must pass through the bimini. I’d like to replace the joint in this pic (clevis pin and split pin) with something that can be disconnected in order to pass the back stay through the bimini as needed when deploying the bimini (I’d like to store the bimini collected and upright/angled, behind the back stay). I see replacement options as clevis pin and hairpin (potentially not secure enough for a back stay), or a shackle. I have quick release pins at the base of each of the stays that I plan to replace with clevis pins and split pins (I see no need and lots of downside for quick release at that location). I don’t know that I trust the ball-lok release for the back stay joint. What options am I missing? Note I plan to add a topping lift and will cleat the mainsheet before I disconnect the backstay.
Thanks in advance for your advice. I have another advice request I'll save for a future post when I get better pics.
Kevin
Back stay removal:
Kevin
