    The turkey is finally gone and you know what that means...
    Welcome to EY.o 2021-2022 Fund Raising Season!
    This is the time of year we come to you to help support the website. Updated information on the hows and whys of fundraising may be found in the post below.
    Thank you for your continued support of EricsonYachts.org!
    Notice on 2021-2022 Fund Raising
e26-2 plumbing diagram - missing thru hull ?
acubria
hi all, I am trying to understand how the head works. I have the option with O/B discharge.
Looking at the attached diagram , I can not figure out where the water for the head comes from.... Is it ocean water or fresh from the tank?
I looks like I have two seacocks in there, one large for the sink and one other smaller (photo) with two hoses a red thiner hose (about 1/2") and a thinker one (black?).
Then on deck I have a pump-out and a water fill .
doesn't the system need a thru-hull to get ocean water for the head?
Andante
On my 35-3 the sink drain and the flush water pick-up tee onto the thru hull valve. It may be necessary to put the sink drain stopper in to pick up flush water when drawing water from overboard. 1 leave the thru valve closed. 2 run water into the sink. 3 Now I flush the head. This will draw the fresh water from the sink to rinse the bowl and plumbing. This procedure works great to winterize the head. Pour the RV antifreeze into the sink instead of water, the pump through. Done
While our '88 boat's plumbing was formatted, by the OEM look of it, to a factory standard, it's good to keep in mind that after several decades and some prior owners a lot of this stuff has, um, "evolved."
(sigh)
First there was the "as drawn" version that might have also generated the owner's manual page. Second there was often some modification in the "as built" version when the shop made some changes due to dealer request, and then the biggie: subsequent owner changes.
Sometimes the later will be logical and well executed, and sometimes... not so much... and sometimes just weird/baffling and in need of remedy. :(
gabriel
Live free or die hard
your boat may have come with a recirculating sanitation system. To the best of my knowledge, the way it attempted to work was by using the “clear” holding tank water to flush. boats equipped with this system (like mine) did not have a raw water intake.
not a very smart idea IMO
acubria
Actually, I was wrong. My system is setup like Andante describes:
  1. the sink drain and the flush water pick-up tee onto the thru hull valve
  2. a second larger seacock looks like the O/B discharge.
This worked : 1 leave the thru valve closed. 2 run water into the sink. 3 Now I flush the head. This will draw the fresh water from the sink to rinse the bowl and plumbing.
But for some reason I was not able to pickup water from the sea, not even with the sink drain stopper... Maybe I am doing something wrong. Will do more testing next week.
Mark F
Hi Arturo,
Does your head sink drain if the through hull is open?
