I was able to successfully get hauled out on one of our club trailers yesterday. My main goals are bottom inspection, bottom paint, and replacing the infamous pre-valve PVC elbows on three of my through-hulls.
While looking around at things on the bottom, I have a few questions I hope to get some advice on.
1) A small chunk missing on my rudder. Is this something I can fill in with some thickened epoxy and then just some fairing compound over the top? Or should I lay some cloth on it? I'm not looking for a major repair/replacement, or something that I need to last me across an ocean, just enough to contain the damage
2) The little ring around the shaft itself is loose. What does that do? Major concern?
3) Anodes - the prop shaft seems an easy one to find. This round one on the strut, does his look like a trim tab anode? Was trying to compare it something I could purchase to replace it with. I'm in freshwater - not sure if that makes a difference on metal composition on these?
