E32-III dorade vent - source
bgary
Advanced Beginner
Had a very nice sail yesterday afternoon, and when putting away the boat I discovered that at some point in the day the "hood" for my Dorade vent decided to jump overboard.
I don't know why it was so unhappy where it was. All I know is that now there is an empty flange on the top of the Dorade box, and it looks so sad.
The flange measures 3-1/4" in diameter where the hood sits on it.
All of the replacement hoods I've seen (Nicro, Vetus, SeaDog, etc) seem to come in either 3" or 4" sizes, but I don't know if that's the OD of the flange or the ID of the hood itself.
Anyone know
-- if there's a replacement for this hood (I believe the original was Nicro)
-- if there's a replacement hood from another manufacturer that will work on the existing flange?
(If not, I may need to replace the flange, too, but I'd rather avoid that if possible)
Pat O'Connell
Marinco Nicro Vents
Hi Bruce
Launch knocked out our Nicro Low Profile Vent in June. I could not make the diameter dimensions work at all. I ordered by Vent Height and it worked. West was no help at all they were out of stock (again.)
What did you get for discovery on your bilge leak?
Best Regards
Pat
1981 E28+ Universal 5411
Bruce,
As I recall I couldn't find a replacement, which is why I painted that one with Brightside.
In adopting stainless cowls to the current boat, I found making an adapter ring of acrylic or Star Board pretty easy--and gave me choice of any cowl.
A big stainless would look raaather good up there....
If it happened to fit, the brand (below) is far cheaper than Vetus, and actually I like the shape better. Never saw one in person....
https://www.marinedepotdirect.com/white-stamped-round-cowl-vent-dorade-set.html
White Round Pressed 316 Stainless Steel Cowl Vent with Deck Plate
Anyone know
I replaced the "rubberized" cowling on my E32-3 (1987) with a White Round Pressed 316 Stainless Steel Cowl Vent with Deck Plate that I found on eBay. Worked out quite well and it looks great. I paid $167 for it and it did include the deck fitting.
bgary
Advanced Beginner
Thanks, all!
I'm going to order one of these from Defender and see if it fits over the existing deck-plate.
http://www.defender.com/product3.jsp?path=-1|6880|2290139|2290141&id=46208
I have very little hope that it will fit, so Plan B will be a decision about whether to return it and get something else (Vetus?), or just take off the old deck plate and use the one that came with the new Nicro hood.
No stainless steel hood for me. I don't do Breton Reds, I'm a shorts-and-flip-flops kinda guy <grin>
Go for the Stainless....
I have two of these in boxes ready to go for when I re-do the stern-rail trim, as the mounting rings for both the existing vents are cracked and covered with silicone sealant (someone else's idea). Purchased from Amazon. I think they'll add a lot to the appearance of the stern. (Had to look up Breton Reds......:) )
bkuchinic
One of my original aft cowl vents was broken when neighboring boat dragged it's mooring and hit the my stern. The threaded base measures 3". I ordered two White Water cowl vents from Amazon today and will report on whether they are a fit. My current vents 'scoop' measures 3" x 5" and are 4-1/2" high measuring from the top of the threads to the top of the vent. The new vents are not as tall at 3". Suggestions for alternatives are welcome.
bkuchinic
Update on Cowl Vent Replacement
The White Water Cowl vents arrived, are very high quality, and appear to be a perfect fit based on the thread size. Photos attached. I likely won’t install until spring.
bgary
Advanced Beginner
Anyone know
An update.... I couldn't find a direct replacement that fit the existing (phenolic) flange, and as it turns out I couldn't get the flange off - it appears to have been glassed/epoxied into place on top of the dorade box, and I didn't feel like making the project bigger than it needed to be if I didn't have to.
What turned out to work, though, is a "tall" Nicro hood with a slight modification.
https://www.fisheriessupply.com/nicro-oval-pvc-cowl-vent-with-deck-plate-mount-n10963
This model comes with the deck-plate fitting glued into the bottom of the hood. Turns out the inside diameter of the hood itself is exactly the right fit for that phenolic flange. So I cut the fitting off the bottom of the hood and placed it over the flange. Fits perfectly and (if I felt the need) could secure it in place with a hose clamp or a couple of screws, but at this moment it is a tight press-fit and works great.
If anyone else has that same phenolic flange... food for thought.
Bruce
vanilladuck
E32-3 / San Francisco
Found this thread after measuring to replace the existing crustaceans which once resembled cowls on Rumour.. and becoming thoroughly confused about the sizing. Just ordered these for the two stern and one mid-deck:
RCsailfast
E35-3 Illinois
Installed new white stern scoops 2 yrs ago as the ones on the boat were sticky and looked bad.
the new ones looked great for abou 3 months then yellowed and got sticky too. The Admiral dropped one over trying to clean it. capped it off and can’t bring myself to get another white rubber one. May go stainless when the stern rail gets refinished this winter
Filkee
Rust oleum was my remedy this year. Made the rest of the boat look dirty…which led to additional efforts.
