Hello-
I am trying to sort out sails prior to the summer sailing season, and could use some advice
Specifically, as I will keep the roller furling for another season (I do listen) it will be hard to change jibs. All summer I will have a 100% up. In the (SF Bay) afternoons that's fine upwind, but there are the lower-wind mornings, and the downwind which is much more entertaining if one can pop a larger sail. Plus outside the Golden Gate it can be a lot quieter. So I would like a big, light, easy-to-deploy (and manage singlehanded) sail. I imagine a spinnaker-like sail with a free luff (attached only at the tack, clew, and head), which I can set/douse easily with my jib rolled, or possibly later fly wing-and-wing with the jib.
As far as I can tell, amidst a huge proliferation of names, these types of sail come in two main varieties:
Gennaker: a big jib with an unsecured luff, made of spinnaker-type cloth, with the tack and head inside (aft of) the forestay. May have (e.g.) a spectra line in the luff to allow tensioning it significantly. Tacking or gybing requires bringing the sail through the foretriangle.
[n.b.: I have handy holes in the anchor fitting that would allow shackling the tack aft of the roller furler]
- I am unsure if this is the same as a "drifter", which is what my sailmaker suggests and describes in the same terms. He suggests a size ~ 150%.
Cruising asymmetrical: very similar; maybe bigger and with more draft (?). Secured at tack and head outside (forward of) the forestay, allowing gybing the sail outside of the forestay in a very simple fashion.
[n.b.: I have no convenient place to secure the tack, but perhaps could drill a hole in the anchor fitting forward of the roller furling. I believe the second foreward halyard is inside the forestay (i.e., not a spinnaker halyard, though maybe I'm wrong -- need to get the binoculars and look carefully), which may present additional problems for this alternative.]
As far as I can ascertain, the cruising asymmetrical is most useful farther off the wind (and a lot easier to gybe), while the gennaker/drifter is better for going vaguely upwind to a deep-ish broad reach, but more of a pain to gybe. I'm unclear if it matters which one gets in terms of utility wing and wing with a 130% jib. My sailmaker has suggested the "drifter", as described above; he is a multi-transpac vet, so should know, but... the asymmetrical sounds sort of easier to deal with to me (the gybing thing seems nice), assuming I could find a way to rig it.
--> I am unclear which format (genneaker vs asymmetrical) is most generally useful for a singlehanding non-racing Ericson; would appreciate any comments/advice.
PS: I have no pole, and no ring on the mast to support one. Of course, that (or a mast track) can be added, and eventually I will rig this, but not having one now I am also interested if one (or both) of these sails requires use of a pole.
Many thanks!
References in case anyone else is ever searching this:
https://ericsonyachts.org/ie/threads/headsail-size-selection-e34-2.19524/#post-152463 (in which Goldenstate has a picture of an asymmetrical; thanks!)
ATN makes a spinnaker sleeve (for dousing) and a "tacker" which I am a little less sure I understand the point of, but seems recommended for asymmetricals. However, it is suggested (https://ericsonyachts.org/ie/threads/32-3-spinnaker-rigging.13255/) that the tacker is unnecessary and skipping it allows rolling out the jib with the spinnaker set.
Many thanks!
E26 : Installing a Pad-eye ring on the mast
It looks like finally after a couple months, my whisker pole will arrive shortly. I need to install a mast pad-eye ring for the whisker pole. ( I didn't want to go through the expense of installing a track and I only have 1 headsail). Most of the fittings on the boom and mast are rivets...
ericsonyachts.org
E26-2 : D-Ring (or something?) for whisker pole setup
My boat came with an old telescoping whisker pole. But there is no place on the mast to attach it. We hooked one end to the D-ring assembly (I have no idea what it is called) at the bottom of the mast where the vang is attached. I'm trying to figure out a place on the front of the mast to put...
ericsonyachts.org
Drifter vs asymmetrical spinnaker
Looking to add a light weight sail. Was thinking asymmetrical spinnaker (see previous post) but have been reading about drifters. I Sail solo most often or with inexperienced crew. Would a drifter be easier to handle with reasonable good performance. Thinking I could add a Solent stay to hank on...
forums.sailboatowners.com
