Hello folks-
I have someone running cable for my mast, and they want to know the total mast length. Of course, they need to know... now, and I... can't find the number. Of course I know my bridge clearance is < 53', but what is the mast length? It is keel-stepped, below the waterline.
--> I need this for an E34-2.
Per sailboatdata.com, the 'P' boom-masthead measurement is 39.0 ft. (and that has worked when I got a new main, so must be right), but I don't know where to look for the actual total mast length. [N.b., my boat has a Lefeill spar, not a Kenyon -- it was built by Pac Seacraft. Unfortunately, Lefeill no longer sells spars, so it is hard to get numbers for the mast... but everything else matches the E34-2 specs, so probably this too.]
I can find here, from Tom Metzger, that
"Based on the rig layout drawing in owner's manual on this site (my note: manual for an E34, not 34-2 I think) I found the mast height to be 44' 4" above the coach top and that the mast is buried 6' 8" below the coach top. Therefore it is 51' mast. I scaled the drawing and found the mast goes 15" below the water line. Allowing inaccuracies, I am confident the mast is less than 50' above the water, not counting the anchor light, antennas, etc."
ericsonyachts.org
But here I see 51' clearance (where I got 53'... I do not know. But better over than under
--> If anyone has the actual number, it would be very much appreciated!
Oddly the manual gives the (Kenyon) spar cross section, etc., but not the actual length.
Many thanks!
Mast Height Above Water - E34 MKII
I would like to know the heights of bridges I can pass under. Thanks Steve
Many thanks!
