One of these FenderSteps came with our new to us boat. It is old so it looks awful but it’s been very handy and won’t damage the hull.
The stern ladder you have is similar to the one on our 30+ which I like because you can tie a short line that hangs down that a swimmer can reach from the water and pull down. You can put some wood blocks on the steps to aid traction.
The 34-2 arrangement is a complicated affair with clips and pins on both sides that can only be accessed from the cockpit. Our surveyor made a note of this as it is not up to current safety standards.
Apparently the ladder is supposed to be accessible from the water even in the stowed position. It’s all too easy to envision Christian’s horrifying story happening if one were to fall in while solo. The freeboard is just too high to climb back aboard. I will likely remove the clips and use a very light Velcro strap or mini zip tie to hold the ladder in place along with a rope that you can reach from the water. A good tug should hopefully bring the ladder down. Of course now the ladder is at risk of opening by itself or by being pushed which then leaves a big gap in the stern rail that you can fall out of. At least the ladder will be accessible at that point!I'm not sure how this fails safety standards
The Ericson-installed stern ladders typically extend below water about 6" (+/-) when lowered. The bottom step swings a pretty wide arc on the way down. If you're in the water and trying to deploy it by pulling on a rope, there's a pretty high likelihood it's going to hit you in the head on the way down. That would not be a good outcome either.Apparently the ladder is supposed to be accessible from the water even in the stowed position.
That pushpit configuration is exactly what we have on our boat, with very minor variation for the different transom angles. Many boats don't have a stern ladder at all so I'm not sure how this fails safety standards. Tho, since it's there it would be better to have something to facilitate deployment from the water and boarding.
I really like the unobtrusive style of this:
View attachment 54432 View attachment 54433
But easily installed options exist:
View attachment 54434 View attachment 54435 View attachment 54436
You got that right. The arc is absurd. Even lowering it from above isn't exactly a smooth and easy operation. And if you have a dingy on a davits like we do, fuhgeddaboudit. Like Christian, we keep it down when moored or anchored. Echoing some above sentiments, the push-pin gate lock arrangement makes the ladder pretty useless from the water if not already lowered. I don't single hand, so haven't really worried about it, but if I did, would definitely alter it. I also have that Edson step and the Plastimo ladder, but unless you keep them deployed constantly, not sure how helpful they'd be in a single-hand situation. The Edson step especially, which would slam all over the hull if left deployed while sailing.The Ericson-installed stern ladders typically extend below water about 6" (+/-) when lowered. The bottom step swings a pretty wide arc on the way down. If you're in the water and trying to deploy it by pulling on a rope, there's a pretty high likelihood it's going to hit you in the head on the way down. That would not be a good outcome either.
