I’m going to send the bits to them to make sure it comes out right.I did this project on my 38-200 and the Garhauer replacements required widening the holes in the deck and aluminum backing plate (that holds the tie rod).
As far as I know, the u-bolts on your 32-3 are a size smaller than the ones used on the 38 (not sure about the 34 and 35).
Successfully extracted first U bolt today. No bad balsa but the top of the block is a wee bit rough. If this is 40 years of deterioration, can I clean it up a bit and go for 40 more or is that bad parenting?
I think it is fine with a clean up and paint/dialectic grease long as there are no cracks.View attachment 53868View attachment 53869
If you're not replacing the rigging wires (if original, I probably would), there is almost no conceivable reason to replace those (very nice and high quality) BRONZE stud turnbuckles.For a minute I got kind of expansive and thought, “Oh, while I have these things pulled apart, I might as well replace the lower turnbuckles and screws,” but then I looked at the price (on Rigrite) and my head exploded. Is Navtec like Apple or is there a reasonable alternative?
