MCD
Hi all,
We replaced the standing rigging of our Ericson 38 earlier this month.
The boat stayed in the water for 10 days without the mast between unstepping and restepping.
After the new rig was installed, we started noticing cracking sounds in the cabin, when someone steps on the boat or sometimes without anything else happening.
I am starting to suspect the cracking sounds are coming from the grid.
What would you advice to do?
I am planning to start by detensioning the rig a little (half a turn on each shroud). We still haven't reinstalled our boom, so that's on the list too, although it is unclear to me if it should change anything. Would you also want to visually inspect the grid itself (in our case, under the glued floorboards, so a pretty big job)?
Last: maybe, I'm oveworrying and this is normal. If so, have you had a similar experience if/when you replaced your standing rigging?
Marie
Marie
