paul culver
I'm finally getting to this project and I was going to use Front Panel Express to make the new panel with cutouts for gauges etc. The original panel material is some sort of plastic. Do I need to stay nonconductive? The gauge housings will be grounding to the panel. FPE prefers to work with anodized aluminum but they will use other material if I provide it. If I need to stay nonconductive to be "in code" is there a particular material I should use?
