markvone
I usually leave my engine raw water thru hull valve open because it is difficult to access. We just had Tropical Storm Isaias and I closed all the hull valves as part of my storm prep. I've read you can hang the engine key on the hull valve handle as a reminder to open the valve before you start the engine. I usually hang my engine key on a hook at the Nav Desk for convenience and came up with this alternative reminder. I have to remove the black fob first when the hull valve is closed. Normally, with the hull valve open and the fob behind the key and reversed, I just grab the key and start.
Mark
Mark
