Ditto.I have an e 34 which also pulls to port under power but I see little or no pulling or prop walk in reverse, strange.
Ha! ;-)Ditto.
Every explanation of "prop walk" that I have ever seen has been completely unconvincing. Unfortunately, this applies to almost all of the "physics" of sailing, especially the ability of a sailboat to go to windward. I would never admit to this (I'm a retired particle physicist) but we're all friends here.
I was doing a Rockford turn every time I went out. The last thing I did before winter set in was dock in a new slip. It's not going to work like before.a good deal of prop walk to port in reverse.
Yep, our '73 E27 pulls to one side while under power. That said, while motoring we usually let the robot (A Simrad TP32 tillerpilot) drive.I recently purchased an 1976 Ericson 27 and have found it pulls fairly significantly to port under forward engine power. Do other Ericson 27 owners experience the same? Are you aware of any corrections possible? Thanks.
I think the offset is deliberate to try and reduce the pull while under motor. Our E27 is an inboard conversion (shipped as an outboard version, retrofited to a yanmar 1gm10 in '83) and the shaft comes out about an inch to starboard from center.Hello,
I dive my boat regularly to clean the hull, I have noticed my prop is offset to Port as well, and I believe that is what causes the pull.. especially when motoring. Under sail I don't notice it much unless I'm heeling.
E27 by chance or?? My E27 was retrofitted to a Universal Diesel 3-20B.I think the offset is deliberate to try and reduce the pull while under motor. Our E27 is an inboard conversion (shipped as an outboard version, retrofited to a yanmar 1gm10 in '83) and the shaft comes out about an inch to starboard from center.
More likely to remove the shaft without dropping the rudder.I think the offset is deliberate to try and reduce the pull while under motor. Our E27 is an inboard conversion (shipped as an outboard version, retrofited to a yanmar 1gm10 in '83) and the shaft comes out about an inch to starboard from center.
