Ericson 29 - master spreadsheet of all boat parts
zebular13
In nine years of owning my 1974 Ericson 29, I've probably replaced half of the parts on the boat, and lots of them have been replaced more than once :-D
I just realized that this would have been a lot easier if I had had a master spreadsheet of all of the parts on the boat and where to find replacements (and whether or not I already had replacements). I started putting together a google sheet today, and I wondered if any of you have successfully created a master spreadsheet like this?
If so, could you share your templates?
Obviously every boat will have different slightly different parts, but I think it would be helpful to have a template to start from, so I'll share mine here when I'm done!
Well... I have spreadsheets. The primary repository of boat knowledge is supposed to be the boat's manual and maintenance log books. Though a lot of the information might benefit from being organized into spreadsheet form. If you look at the "manual" that Ericson left us with, it's filled out with a seemingly random and incomplete selection of 1-page drawings of various systems. As if the owner is invited to complete the manual on his own, with relevance to the specific boat. Arguably, each drawing ought to have a table of info about the parts shown. And I literally have a tub full of equipment manuals (that come in every size and shape imaginable, so as to defy organization) sitting in my office, awaiting some sort of organization. And a binder full of crude drawings, measurements and notes that I generated in the process of various projects.
IDK how "successful" my spreadsheets are. I may have to re-think the whole approach. Just in trying to describe them, I begin to see how they might be better organized. Probably, I should just stop here.
But:
I started a "rigging" spreadsheet. But now I see that it never got filled in from my handwritten notes during the re-fit, which are around here somewhere... It has four tables: Running Rigging, Standing Rigging, Sails, and Deck Gear. Five Tables: Just added Anchoring.
For running rigging, the columns are "Line, Length, Diameter, Material, Color, Source, Date in service, Note." I had great plans to work out a master color scheme, but when it came down to it, there weren't adequate color options available in the rope that I needed. Also, "length" ends up depending on whether a halyard (for example) stays at the mast or gets run aft to the cockpit.
Standing Rigging. Cable, length, diameter, terminator, pin size, source, date in service, note
Sails. Sail, Area, Luff, Leech, Foot, material, weight, Source, Date in service, note (separate lines under the main for each reef point.)
Deck Gear. This is a hodge podge of stuff like the roller furler, the traveler, mainsheet, deck organizers & such that don't have many common data points. Item, brand, model, serial#, source, date in service, note. There doesn't seem to be a level anywhere that captures things like individual blocks and cleats. And I just fabricated a stack pack and lazy jack system, which is a wad of stuff all on its own...
Do dock lines (and fenders, etc.) go under "Deck Gear" or "Running Rigging?" What about storm drogues?
Back up to paragraph 1: maybe the system diagram with accompanying parts table is the best way to capture this.
Mainsail and controls, Headsail and controls, Spinnaker and controls, Anchoring systems, Docking systems, etc. Then a master spreadsheet might capture the data from each "system" table, organized by system. (Does the Master spreadsheet really need details like the first aid kit contents? What about all the parts of the roller furler or the galley range? If not, those manuals need to be (found) kept and organized.). And if some object doesn't fit in any of those "systems," what do you need it for?
Other Spreadsheets:
Electrical Loads: Device, Amps, Volts, followed by load calculations (Hours used, amp hours) for three different use scenarios. This sums up to requirements for battery capacity and power. Separate table of Power Inputs (Source, watts, efficiency, hours per day, amp hours)
These tables include both items on board and items I've been considering, to see how feasible they are and how they would affect the systems. And some values are measured, while others are estimated.
Ships Manifest:
This is the one I've put the most work into, and overlaps with some of the other stuff. It's partly to have a record of all the stuff on board (or considered) and partly to decide how feasible it is to cruise and live on board this boat. Probably need to start all over.
Item, Make, Model, Serial Number, Weight, Date Installed, use (day sailing, cruising). This somewhat randomly includes everything from anchor chain and the water in the tanks to the scuba compressor and the bicycle. Typically "day sailing use" items are installed on the boat and "crusing use" items would only be loaded on if I were heading out on an expedition. There may be some estimates and some wishful thinking involved.
It does not capture, for example, the weight of all the wire, terminals, & etc. needed to install all the gadgets. Nor the shelves and such that I've added. Though it could if I had been more diligent. But Every Possible Thing adds up to about 2500 lbs. Not too far off the "one ton per person" rule of thumb for cruising.
Still, now that it comes down to (or closer to) actually moving on board, the whole spreadsheet thing is inadequate because I still can't tell how feasible it is for all of this stuff to actually fit on board without looking like a hoarders nightmare. Still need volumes for all this gear and a stowage chart. Short of actually hauling it all to the boat and doing the practical exercise. Which it will certainly come down to in the end.
Many of the items on the spreadsheet were thought exercises at the time, but now they're physical objects that I have to decide whether to leave behind or not. Sure, I could give over the whole V-berth to workshop and storage. But then, I'd put my clothes... where, exactly? Can I keep the sewing machine? What about all the tools and supplies that go with it? (Actually that started out as the "sail and rigging repair kit" but somehow it got out of hand...)
Then there is a table called "Performance Effects" that draws values from some of the other tables and tries to compute some crude idea of the effects of boat loading and alterations on various published (themselves, admittedly crude) parameters like SA/D, Motion Comfort, Capsize ratio, Theoretical speed, and inches immersion of the boot stripe. The calculations are somewhat reassuring, for what they're worth. But when I had the boat all stripped down, I should have painted the barrier coat right up over the stripe area.
nathanmccusker
But:
Other Spreadsheets:
Ships Manifest:
Hello,
Would you be willing the send over a copy of your spreadsheet. I'm working on inventorying my new 1975 E29. Right now I'm breaking as a reserve study for replacement.
bgary
Advanced Beginner
For a while I kept a spreadsheet of "stuff on the boat" so when I couldn't find something I had at least a trail of breadcrumbs. Like, "where the hell did I put that partial roll of butyl tape?!?". Was a lot of work to keep current, and it never was anyway, so I stopped. So it goes.
On the other hand, I keep both my "log" and my "boat notebook" in OneNote (a Microsoft app, but there are similar things from Google and Apple). The beauty of OneNote is two-fold: one, it's pretty free form - you can type free-form info, you can organize stuff in tables, you can paste in photos, you can even write in it (and it does a halfway decent job of producing the text of scribbles)... and it's all searchable. two, it lives in the "cloud", so the info is accessible anywhere. I can add info on my laptop at home and the next time I'm at the boat the info is on the iPad at the nav table.... and I can take a photo on the boat and it shows up in the "notebook" on my laptop. Etc.
Relevant to this thread, the "boat notebook" is sort of the collecting place for all the info I have about the boat and the stuff on it. I have a section for rigging, a section for engine and mechanical, a section for plumbing and systems, a section for electrical and electronics, etc. I have everything from contact info for the travel-lift operator at the marina, to hand-drawn sketches of the locations of all the thru-hulls and the plumbing to them. It's proven to be super useful... for example, if I'm standing at the auto-parts store and don't remember what the part-number is for the WIX oil filter, I can pull out my phone and look it up in my notebook. If someone asks how long I made my spinnaker halyard... I've got the info. I have everything from
Works for me. Yeah, it does take some discipline to keep it current and organized, but I've found it to be worthwhile.
$.02
Bruce
PS - while I'm at it.... I've long been in the habit of keeping a "deck log" - a small (pocket-size) Moleskine notebook that's always on deck and handy for jotting things down as they happen. Engine hours, fuel-fills, waypoints, tide changes, conditions, whatever. "0926, passed the possession point bouy, big tide-line 100 yards to the east. 2200 RPM, SOG = 7.1 with current-push" Etc.
At the end of a trip, I'll capture the interesting/useful bits and transfer them to the "smooth log" (a navy term, I'm told), which lives in OneNote as more-or-less the permanent record of the boat's adventures. Which means that... if I want to know how many hours I've run since the last fill, or the actual on-the-water GPS coordinates of the Admiralty Head bouy from the last time I passed it... I've got it available on my laptop, on my boat-iPad, wherever. Again, takes a little discipline but I enjoy it, and it's proven to be useful.
sdwnav
If you want a way to catalog equipment I'd suggest something like the Navy Ship Work Breakdown System (SWBS) to organize it. SWBS is kind of like a Dewey Decimal System for ships. So for example 233 = Diesel Engine. It is meant for ships so there aren't pre-defined buckets for the sailing rig, but I'd put that stuff under the 200's.
PDF here, the SWBS list starts around page 30
  • SWBS List.pdf
