Ericson 30+ aft keel bolt nut replacement
flycavalry
I was moping up some water in my bilge with my wet/dry vac and decided to clean under an inspection plate for the aft keel bolt. The water was from rebuilding my head pump (yuck). I can see the bolt clearly but the nut looks like a rusty mess. It does not look like the nut could have been tightened all the way down by the way the hull is designed there. I am thinking about grinding off what is left of the nut, cleaning/treating the threads, and installing a new nut. I was also thinking about building up the contact point where the nut and washer will rest with epoxy. Does anyone know what size the nut is for the aft bolt and the torque that should be applied to it as well as the torque for the other bolts forward of it. My boat is a 1984. Comments and advice please. Thanks
I've always heard that one can only reasonably tighten keel bolts when the boat is on the hard, not in the water due to the weight of the keel. I think I recall the nuts being tightened to 150 lbs. but I'm not sure of that.
If the washer and nut don't sit flat and even, I wouldn't hesitate to build it up with epoxy to ensure good support. I would not use Bondo or similar junk sold in some stores.
debonAir
It seems intuitive that you'd want to torque the bolts on the hard so the weight of the keel is supported and the weight of the hull "helps", but really, I think that if the keel bolts can't easily pull up the weight of the keel then they're not really up to the job of keeping it attached are they? The torque specs for the bolt/nut pairs are typically near to (with safely margin) the elastic limits of the bolts, otherwise a smaller/cheaper bolt could be used. The tension on keel bolts properly torqued are vastly larger than the weights of the hull and portion of keel being supported. A single 1 inch stainless bolt has a minimum tensile strength of nearly 70,000 lbs. (304 or 316 alloy) meaning you could easily lift 2 or 3 *times* your whole boat and keel off the ground with a single keel bolt and only load it up about half way. If your bolts aren't torqued properly they are subject to flexing/sheer loads and oxygen depleted salt water which are bigger concerns (in my opinion) than where you do your torquing.
It's not that the bolts can't take it, it's that you will find it challenging to snug up the nuts on the bolts if you also have to lift the 4,000 lb. keel. It's much easier if the keel is supported on the hard, as then you're just dealing with the torque requirements of the nuts on the bolts. But that's just my thoughts, and I could be mistaken. ☺️
Flycav,
You may possibly be overthinking this. Clean the rust off the nut with a wire wheel and see what you've got. It's stainless, and there's probably plenty of metal left. If there's pitting of the bolt itself, same deal. If the keel bolts aren't leaking there is likely no issue. All keels flex, few keels exactly conform to the hull shape, most keel/hull seals need recaulking.
Take a picture, others can compare to how their boat looks.
debonAir
That was the point I was trying to make: A single keel bolt torqued properly is pulling close to 50,000 lbs or so. Lifting just 4000 lbs is trivially easy for even a single bolt and you'll have a number of them, say 4 bolts needing to only lift about 1000 lbs each. A short ratchet on the nuts would suffice for that.
Or think of it this way: torquing the nuts on the bolts will result in tension (pulling) in the bolts proportional to the torque, but much larger. That tension is simply that: tension, and is independent of what weight, if any, is hanging on the bolt. If there were more weight in the keel, there would just be less compression between the keel and hull for that given bolt tension. The tension force of the bolts (say 4 bolts pully 40,000 lbs = 160,000 lbs) is much larger than the weight of a 4000 lb keel so the keel is insignificant in the static forces involved, supported or not.
A note I made in an old file says "keel bolts 250-270 ft-lbs." I know I got that from an earlier post on this site. I'm assuming that is for the larger (mid) keel bolts and not the smaller fore- and aft- bolts.
debonAir
torque is based on the bolt size, more for bigger. The actual value to use depends more on the material/washers/location than it does for the bolt. If you torqued a 1" bolt to it's actual breaking limit (probably close to 100,000 lbs on the bolt!) it might push your nut right through the keel stub.
For most boats
1/2 (small) bolts get about 80 ft-lbs
3/4 (mid) bolts 150-250
1 (big) bolts 250-350
J-boats recommend 165 for 1" bolts in J/109, for example, so there are variances and boat specific values.
Since 300 ft-lbs is a lot of torque, most people don't have a way to practically apply or measure it. Think of wrenching a nut as hard as you can with as big an extension as you could fit perpendicular in your boat. Use the length of extension as the "torque" value, using "as hard as you can" as the constant. Say 1' or 2' extension for 3/4 or 1" bolts if you can lift 150lbs with both hands without a lot of pain.
flycavalry
Water in the bilge?
I am trying to determine the cause of water in my bilge after I sail. I am not sure if it is coming from my shaft seal or if it is from the keel bolts or possibly both. If the boat is sitting in its slip and their would be a problem with the keel bolt seal how much water could I expect to seep in over time? I am trying to determine if the condition of the keel bolt nuts were caused by water being left in the bilge from sources such as the shaft seal or the mast.
Sneaky Leaks
While and After sailing, one place to look is the rudder shaft. There is a stuffing box there and most of us forget to check it for decades at a time. :confused:
Shaft seal is an obvious place, and you can check it when the shaft is turning, and then again at rest when back at the dock.
Gaining access to the rudder shaft and prop shaft can be 'challenging' on some models, from anecdotal evidence I have seen here.
Keel bolts are a lower percentage possibility. I had seepage around one bolt when we acquired our boat, and a few years later had the keel dropped and re-bedded - never a leak since. There is a quite a large thread here on keel re-bedding and the potential risk to the bolts from corrosion.
As an E30+ owner, the things I would check are as follows:
1) As Loren mentioned, the rudder stuffing box is often ignored. It is accessible through the port cockpit locker and there are several nuts at the stuffing box flange, which should be snug. Mine kept loosening, so I added lock nuts and that solved the problem. There are also 2 zerk fittings, one near the top of the rudder shaft (very hard to see) and one under the plate at the bottom of the shaft (also hard to find, but they are likely there). With a grease gun, add lots of grease to both fittings, being careful not to break the zerk fittings off as you remove the gun. If it is leaking water at the stuffing box, you should see it being a bit wet after a sail with the boat heeling.
2) Stuffing box leak is a possibility, but if you put a paper towel underneath it, or some white chalk, you should be able to see if it gets very wet while the boat is in it's slip. If so, tighten the stuffing box, or replace with a dripless shaft seal next time you haul the boat.
3) The keel on the E30+ does flex a bit during a hard sail, and water can enter the bilge if the keel/hull joint hasn't been recaulked or sealed properly. Rebedding the keel solved this on my boat--not a cheap job, but maybe necessary after all these years.
4) If I overfill the optional forward water tank (under the V-berth with the deck fill at the bow), I get a bit of water in the bilge for a day or two after. Similarly, if you have a leak in any of the fittings or inspection ports on either of your water tanks, or holding tank, that water will end up in the bilge.
5) If you have a leak in the connections under the galley sink, that water will also end up in the bilge.
If you have the E30+, as far as I know they are all deck stepped masts, so you should not have any water from the mast in your bilge.
With careful inspection of these various possibilities, I'm sure you can determine the cause. Good luck!
kapnkd
kapnkd
While and After sailing, one place to look is the rudder shaft. There is a stuffing box there and most of forget to check it for decades at a time. :confused:
CORRECT! ...Our E32-II would always have water in the bilge after sailing or even just motoring. It WAS indeed coming from the rudder post stuffing box. As the boat naturally squatted on her stern while underway, the box went below the waterline and water would then flow to the bilge. (Seems Ericson never sandwiched any “stuffing” in it when built.)
Once a proper seal was established, she now stays dry.
The test is to tape a dry paper towel on the rudder tube gland (where the rudder post enters the boat).
Then proceed under full power, so the stern squats, and see if the gland leaks water in.
