probably a sliding gooseneck downhaul. In theory you can use it to tighten the luff of the sail. In paractice I have found it better to pin the boom to a fixed place on the mast. Then control luff tension either with the halyard; or with a mainsail downhaul (also called a Cunningham) the goes through an eye around foot above the tack of the main and down to cleat usually on the mast near the gooseneck (or it can be led aft).
The Cunningham does not keep the boom from rising when sailing off the wind.
For that you need a vang.
A vang is usually a multi-part tackle from an eye on the boom 4 - 6 feet (or so) aft of the gooseneck and then to the base of the mast . It can be cleated on one of the tackle blocks, to a fixed cleat at the base of the boom, or led aft. My layout is a cam cleat on the tackle (similar to main sheet - I have used a van as an emergency mainsheet). I usually just fix the vang, gooseneck, and the boom topinglift, and forget it. That keeps the boom at all times in a plane perpendicular to the mast.
--Steve
