c.jbrowne92
Potential for a sale of a well kept / restored ericson independence / cape liberty 1979 hull.
location. Rio dulce - Guatemala
I have been restoring the boat for over 18 months and sailed down to Guatemala so well seatrialed! I’ve done so much to the boat and no expense was spared. I’m selling due to moving to australia and after some thought Im deciding to let her go. I know the boat inside out so you can get a full handover of systems.
2019 beta marine 25hp - fully serviced and cleaned - new coolant, impeller, heat exchanger pulled & cleaned . Updated 75ah alternator, r&d flex coupling and new shaft side coupling from beta, New cutlass bearing, new engine mounts,
full sand of hull below water line - I repaired 26 minor osmotic blisters, 4 x international 2000e barrier coat and then micron CSC topcoat, full repaint of hull above water line - fighting lady yellow and artist finish on bow sprit
New 12v complete refrigeration plant installed.
can come with starlink mini and mount
all underwater through hull and seacocks from groco and backing blocks installed, new hoses where needed
calorifier for hot water from the engine, cockpit shower
new black water tank and hoses. And new jabsco macerator pump
Raymarine st4000 autopilot full rebuild and spares included
5gph water maker module style which I built myself.
220ah lithium house bank, 400w solar, dcdc / MPPT charge controller, 2000w inverter Bluetooth enabled, fire 10HD tablet to monitor garmin chart plotter, solar & radar from interior.
interior LED lights, lots of new 12v & 110v wiring.
New shore power charger
1800w generator
whale emergency bilge pump rebuild, 2x rule electric bilge pumps (one with float. One fully auto
Almost all exterior wood has been varnished / repaired where needed
running rigging replaced 2025, standing rigging 2019 / 2025 (bow sprit) sails are in great condition
electric windlass - 240ft chain - painted per 25ft
2x starter batteries
Baby Blake’s head - fully serviced and service kit spares onboard
5x 5gAl Jerry cans, full professional clean of fuel tank, rebuilt 12v inline fuel polisher, new fuel hoses and valves
so many spares & tools onboard you can walk on and continue with the cosmetics and making her as you want,
many more upgrades will add as I remember, any questions feel free
there is mostly cosmetic work left to be done now as she is a 1979 vintage, my list is ongoing my current projects were going to be repair and paint the deck, i have found 2 small soft spots which need to be addressed in non critical areas.
Painting of the cockpit and sanding back all bronze to polish finish. I will be back in Guatemala to keep going on with these projects as if she doesn’t sell I will put into a longer term storage mode and keep her for when I get back.
we can go through details of projects I have outstanding and will give full clarity for piece of mind.
Honest seller, I work on super yachts and have taken much care in my boat as a big project and too a standard I would be proud to call my own work.
1800w generator
