barely adequate
I've noticed over the past couple months of cruising that the m25 in my E27 goes through a lot of coolant. Recently I noticed some in the bilge, and almost none in the reservoir, so I realized I had to deal with it right away. I added coolant, started the engine with the covers off, and stood by with a flashlight watching for leaks. I'd expected a faulty cheap hose clamp or old hose (have been replacing these as fast as I can get them since I got the boat a few months ago), but instead, when the engine reached around 150°, coolant started dripping out of the unoccupied small hose fitting just under the reservoir cap. I assume this is why the old alternator kicked the bucket (it was right under the drip, severely corroded, and non-functional), and I'm hoping to prevent this from happening again. The engine otherwise has run well until now and holds temp at just under 180° once it's warmed up. So, a couple questions:
-Is the coolant reservoir cap (or something else) likely defective, or could the loss be due to normal cyclical expansion/cooling of the fluid?
-can I add an overflow/expansion tank to solve this, if so, can anyone recommend an affordable aftermarket one? I'm guessing this isn't something you'd need to go for OEM parts on? Could I maybe even find one at an auto-parts store?
Here's a photo of the current situation:
https://drive.google.com/file/d/0B8-8UI9ISKB_eDQwX2p0aW1oY0U/view?usp=sharing
