adam
I was climbing the ladder yesterday, and the screws pulled out, sending me crashing to the floor. (photo 1)
Here's what I'm thinking to fix it, and I wanted 2nd opinions before I begin on the project.
1) Fill the screw holes and the gaps with gorilla glue, and clamp the entire ladder together until it dries.
2) Add 6 more screws on each side. (I'm not sure about this -- your thoughts?)
3) Would it help to add a support on the bottom so that the ladder doesn't move around? (I think I've seen photos of these on Ericson 30s)
After that, the ladder should hopefully be solid. But that's just the start of my problems.
There have apparently been problems with the ladder in the past which a previous owner did a very half-assed fix on. For some reason, they rotated the brackets inward and added a bolt to catch the ladder (photo 2). And, with the ladder solidly put together (no gaps), it no longer fits on the brackets (photo 3).
How should I deal with moving the brackets? There are going to be adjacent holes which I need to fill? Is epoxy the right way to do that?
Also I'm pretty sure that the ladder no longer matches up flushly with the brackets, possibly because of the carpet. Maybe this is why the previous owner did the strange "fix". Though, even with the carpet removed I'm not sure it fits. So, what's the proper fix now? Should I rotate/move the part of the brackets on the ladder so that they fit solidly in the mounted brackets? The alternative seems it would be to leave those brackets as is, but shave off the bottom of the ladder. What should I do?
Thanks for any advice!
-Adam
Photo 1:
Photo 2:
Photo 3:
-Adam
Photo 1:
Photo 2:
Photo 3:
