The oil-absorbing pad under my 5432 diesel turned red. Oh dear. Red is diesel fuel.
I figured my aft-most injector body had come loose, since fuel seemed to collect there. I brought the special tools required to tighten an injector.
But another test run narrowed the issue down. The leak wasn't the injector at all, but instead the small hose of the fuel return between cylinder 3 and 4. With the engine running it sent a fine spray onto the injector. That was obvious on a paper towel placed there.
Easy fix, if I can find the odd-sized fuel hose. I couldn't, when I took the Kubota size around to boatyards and diesel shops a few years ago, when servicing the injectors.
I'm guessing 1/4" ID, which might be too large. But the Internet source will have it here in one day, and returnable for free.
