Fuel line Leak Discovered
Good to have the 3/16th citation. Better than my 1/4", although the replaced lines are currently holding OK.
David, can you reconfirm that the hoses in the link above are correct? The link is to "1/8th" hoses, whereas others have recommended 3/16ths and I was able to adapt 1/4". (It might be that the current link is incorrect)
David Grimm
E38-200
They are the ones I am using. The hose stretches pretty easly over the nipples and the clamps fit and work well. They have been in service now for two and a half seasons and countless hours of motoring. They replaced the previous owners clear plastic like hoses that appeared to be held on with safty wire. Big improvement and no more leaks!
David Grimm
E38-200
Here is a zoomed in photo taken right around the time I installed them.
No loss of power, just fine mist of fuel spraying. A return line had split.
I replaced my returns with 1/4" fuel hose, which is fatter than David's, and needs to be squeezed by hose clamps at the nipples. I think the nipple is 4mm, which is 5/32nd inch, (a bit over 1/8 inch), so it's good to know 1/8th hose fits. Or 3/16ths.
Bumbugo13
Christian, quick question. After changing just the fuel return lines, is it necessary to bleed the system?
I didn't have to. The fuel return is on the other side of the injectors, and just carries away excess back to the tank.
Bumbugo13
Yep, thanks. Figured that out. Replaced the lines but as you saw in the other thread...still looking for the leak(s).
