treilley
I removed the quarterberth top this weekend so I can remove the fuel tank for inspection and cleaning. The PO claimed that he had the tank removed and welded to repair a leak in the lower corner. I found that the tank is tabbed down on 3 sides with FG cloth. Is this stock or did someone add this after the fact?
BTW, found a bit of sludge and critters in the tank(looking through sending unit hole). I will be adding a good size inspection/cleanout port for future use. I am thinking of cutting a 4" hole and fabricating a top out of 3/16 aluminum plate. I will tap the holes and use a neoprene gasket. Any other ideas?
