Further evidence of over-building
Installed a new access port next to my battery box the other day. Had to make a 4.5" round hole with a jig saw. The saw struggled a little more than I expected. Turns out the FG laminate is over 1" thick in this area. I think that is probably the same thickness as the hulls of some new construction boats.
Looks like balsa-core to me - typical deck construction - but still plenty thick FRP... I've taken cores out of my deck and I don't recall quite that much lay-up, but it has been a while. And the hull is pretty thick near the keel, but only about 3/8" elsewhere. I wonder if any of those cores are lurking in the dusty corners of the shop?
gabriel
Live free or die hard
Here’s the core of the solid layup off mine near the keel line, it’s 5/16“ thick plus the 1/8“ G10 PL I added for reinforcement , pretty thin actually.
Here's the 381 transom--more than 3/8ths solid. About the same as the cabin house. TAGF tends to be about 3/4" or more.
nquigley
View attachment 39016View attachment 39017
I'm glad you didn't hit that battery cable with the jig saw! I was thinking of putting an access port in the same location but decided not to because I saw a big cable under there when I checked the area from the other port that's closer to the distribution panel.
Exactly! That battery cable was fastened with a screw-in zip tie right about where the center of my new port is. I still have the fuel tank out so I was able to go in from the back side and move the cable. There is also a corrugated wiring conduit immediately outboard of the port (visible in the first picture). I had to be careful to not hit that with the blade as well.
