1911tex
Apparently the surveyor missed it. The PO who owned the boat for a decade didn't admit it. Now that the boat is on the hard or the first time in 3-4 years, pressure washed in prep for a new bottom, it is now so obvious and there are 2 large 4-5" blisters on the port side of the rudder. (thank goodness only a couple very small ones on the hull itself).
I called Foss in California about the possibility of straitening the post. No dice, it will never be perfectly round and possible source of a leak. It seems the rudder must have hit a rock/cable or something that bent the post sternward, just enough that the rearmost upper corner lightly rubs against the hull. You can see a defining bruise on the fore bottom now that the crud is gone. Foss said water intrusion from the bruise may be problematic. So I am going to purchase a $1600 +shipping and installation cost, for new rudder from Foss, Cal. "!@#$%"
My first question is; Foss has a new design rudder for this boat, a picture is on their website; has anyone purchased the new design?...supposed to be more "efficient", according to Foss.
Second question: Looks like the post is 4-5' long...the marina has the machine to lift the boat high enough. What is the procedure to remove (drop) the old rudder and install the new one?
Sure appreciate your kind assistance on this problem! I sure would like to sail again, the lake is magnificent!
I am amazed that there is no evidence of a hit on the keel!
