grounding electric to A4
steven
Is the screw on the front of an A4 a grounding lug ?
It does not seem to be identified as such in A4 literature.
I think the grounding lug is on the block beneath the alternator. At least, there is an otherwise unused stud down there, and that's what I used it for.
Afrakes
Yes. The grounding lug is any point on the block where you can get good contact and easy access. I'm not aware of there being a designated lug on the A4.
kapnkd
kapnkd
The wire attached to your front flywheel cover (lower right at 4 o’clock) is the system ground wire.
ANY wire to ground out against the metal engine block or connecting pieces properly will suffice. (Just like with an automobile engine.)
garryh
mine is grounded at one of the bolts holding down the transmission access plate at the rear of the engine. As Kerry mentions, pretty well any substantial bolt with good contact will do. Painted surfaces and those heavily sludged should be avoided (or cleaned to bare metal)
