    EY.o April Zoom Meeting
Haulout - Bottom paint, Topsides paint, New Name et al
Rosco
Exploring the BC Coast E35-2, Yanmar 3GM30
Well I am on the hard and have been for two weeks with a week to go. I wanted to share some insights on the items in the title in the hope that it helps fellow Ericson owners.
1. Let's start with antifouling as I found a supplier who offers quite a deal which if in the Pacific Northwest should be appealing. Columbia Coatings is a manufacturer of marine paints in Delta BC. They have high quality, old school high copper content antifouling for $150/Gallon. (see Facebook Marketplace) They are a wholesaler only but sell their marine paint to the public....Also have rollers, extendable roller handles, trays, gloves etc for very little money.
2. After a complete sanding of the hull topsides, I applied a base or undercoat, followed by sanding and filling and more undercoat. I then applied the NEW Topcoat paint called Interlux Toplac. I have used Interlux Brightside, which I loved but it is out of production. I have a sense that Toplac is the same paint. I will do 3 coats and employ the Roller Tip method as I don't know how else one would do this. I have done two coats at time of writing. They say no need to sand between coats but I did do a full palm sander round with 320 grit after the first coat.
3. Finally, the fun bit was the new name placement. I did 4 coats on the Stern prior to the placement of the name. Prior, the name was Akevitt and name was forward on the hull of both sides. I favor stern placement and Brubeck has meaning for me (us).
4. The characteristic Ericson stripe at the hull top is now Ocean Blue as opposed to Burgundy. the pictures show masking tape coming lose and is not sloppy painting... tedious little job for sure
5. Lastly, not pictured, are the decks and cabin top which are now white on white.
Note - The yellow ladder in the forth photo is a frenemy. Up and down that nasty thing hundreds of times as the paint tray shelf is lacking.
Filkee
What equipment did you use for sanding? I’ve been putting off attacking the topsides for seven years or so. Gel coat is blistered and I need to go deep.
Rosco
I have a palm sander with 5 inch pads. I bought 100 discs on Amazon, various grits for $20...for your application, 40 grit will do it.
To get deep I have an angle grinder (Milwaukee) with 40 grit fiber discs that can get through gel coat into and through fiberglass if needed. It is aggressive.
BlueCanoe
What did you use as a filler? I’ve used a few different epoxy fillers in the past, I think the Pettit brand was my favorite for being able to sand smooth.
Rosco
Above waterline I used 3m premium. Very easy to work then sand a few minutes later.
Rosco
I'm at Lionsgate. Very good place to have it out for what will be a couple of weeks. I like it because it's mostly trades people and nobody here weekends. I get a great discount because my firm has an office here as well which doesn't hurt.
Rosco
All set to launch. One more bottom coat. Maybe 2...
AdventurousAnton
Today's the day, Rosco! CONGRATS! She looks great!
Post some photos of the launch. Also, Brubeck is my dog Enzo's middle name, and holds special meaning for me (us). Me = sax player.
:egrin:
Rosco
Positive outcome update:
She picked up on we managed to get more efficient as at WOT we now get prescribed Hull Speed of 6.81 and at Cruising RPM of 2800 we are 6.4 whereas prior I was 5.7 knots at 2800 RPM and 6.4 at WOT.
Rosco
Wow poorly written as I posted while on the phone...It should read, She picked up efficiency and managed to get prescribed Hull Speed...
