How's my vertical manual windlass work?
Geoff W.
So I've had this thing for about a year now and I still don't quite get it. I understand the toothy part on the bottom is for the chain, and the winch drum above is for the nylon rode, but what is that sharp little locking tooth for on the bottom? It doesn't seem like it moves.
And the biggest mystery is what is the arm for? I've never seen a windlass with the extendable arm like that, and it doesn't seem to do anything except be a tangling liability. I'd like to take it off if possible - both that arm and the sharp tooth in the 2nd picture are spinnaker-destroyers.
I cannot make out the brand on top. Can you tell us what the make (and model) is?
Not sure how the bottom part functions, but it looks kind of like a ratcheting pawl of some sort.
Geoff W.
It's a Simpson-Lawrence, I think (away from boat currently). No idea what the model is, can't find it anywhere on the device...and have been unsuccessful in googling for a manual or similar :(
It's different enough from mine that I can't really guess about the odd bits... a head scratcher for sure. Mine has a shield that covers the pawl. The upper capstan is for a second (all rope) rode, or for warping the boat with a dockline, or whatever. If it's like mine, the capstan is always connected to the motor shaft, like a non-self-tailing winch. By screwing one of those upper sockets down, you push the underlying clutch plates together and engage the gypsy, which might be for all chain or chain/rope. Unscrew to drop the anchor freely.
Maybe google image for anything that remotely looks like it and download available manuals? Even if it's not the exact thing, it ought to provide some clues.
Edit - that arm looks like it might possibly be something like a pre-feeder for rope rode? Chain feeds through mine pretty easily, but rope has to be at JUST the right angle or it will jam. Just a guess.
Ian't that device on the lower drum a capstan lock? Looks like it's supposed to rotate in and engage the matching cutouts on the drum. If so, it would be in the "unlocked" position in the photo.
Geoff W.
It definitely looks like a lock but appears to be jammed in its current position. Maybe a persuader bar would get it to move. Or some penetrating oil?
Either way I guess I'll take that arm off - I haven't had to use it yet, and it's mostly a liability.
markvone
Geoff,
I have the same unit minus the lower chain gypsy. The locking tooth gets frozen on mine from zero use. Spray it and wait a bit. Maybe a light tap with a plastic hammer at the most. The tooth should pivot in and lock in the notches in the chain gypsy. I agree the bars forward are line/chain pre-feeders.
Mark
