When I purchased my 911SE this last summer, the Navtec backstay adjuster was in bad shape. It was gonna cost about $325 to rebuild the unit, assuming nothing major was busted.</SPAN>
So I replaced the greasy piston and wire backstay with a double ended, 24:1 cascade, spliced to a dynex dux backstay. The system works great. It’s much lighter, more reliable, and adjustable by the helmsman or main trimmer, from their station on either tack. Cost for the system, if you paid list for all the blocks and line would be a bit more than the cost to rebuild the Navtec unit. But who pays list? And I count the cascade as a major upgrade to the hydraulic system.
</SPAN>
Originally I built it with 16:1 purchase, but felt it took a little too much juice to harden up.
</SPAN>
The low friction ring at the top cascade is a good alternative to an expensive high-load Harken block. Although a 40-Series Garhauer block would also be an economical but heavy choice. You could also go with Garhauer for the double and triple blocks. But their small standup and cheek blocks don’t compare to the Harken carbos.
</SPAN>
Hope this helps others weighing the cost to rebuild their hydraulic backstay adjuster.
</SPAN>
</SPAN>
</SPAN>
</SPAN>
</SPAN>
