Ice box drainage
hanareddy
Hi! Does anyone know where the ice box drains too? I have a '73 E 29 and need to clean this thing out. Unfortunately, the discharge seacock for the galley sink is stuck, so I won't try to open it. But, it looks like the ice box drains someplace else. Thank you!
kapnkd
kapnkd
I’m fairly confident your 29 is very similar to our ‘73 E-32 setup.
The drain hole at the bottom of your top loading ice locker/chest simply drains down directly to the bilge and not to any close by thru-hull valves.
(Probably because the ice chest bottom sits much lower and would be subject to outside foul water contamination rising up via the thru-hull when healed over.)
It’s difficult (or impossible) to reach from underneath as the ice locker was heavily foamed all around, including the bottom back then. You maybe able to feel a plastic drain hose leading towards the bilge - but wouldn’t bet on it.
I can't remember if the hose connection to the ice box is accessible, but the hose just hangs down into the bilge, under the ladder. I neatened mine up a bit by securing it with a weld-mount tie and put a PVC valve at the bottom to keep the cold air from draining into the bilge all the time.
Slick470
Grant, Check your Olson 911, the factory arrangement drains into the bilge too. I still need to change that on ours.
Boats with refrigeration, an option, probably also have an inaccessible icebox drain. Should be plugged I am told otherwise cost in frig efficiency is high.
Alan Gomes
Sounds similar to my E26-2. I don't have a refrigeration unit installed but just use ice. What I did is hook it up to a small ShurFlo electric pump and then ran the output of the pump to a small spout I made from some plumbing bits and mounted into the top portion of the sink.
frick
my 1971 e29 drains to the bilge.. so after a few weeks of use at the beach, I have to clean the bilge to remove the stick of what food particles washed down there.
garryh
"I have to clean the bilge to remove the stick of what food particles washed down there. "
from my first boat 25 years ago, I could not believe what a dumb idea this was. Draining an icebox into a (mostly) inaccessible bilge area..? spilled milk/chicken guts/steak blood that just has to happen eventually....?! just a really dumb idea
Icebox water was always a problem not easily solved. In wooden boats, the icebox drain was the first place the surveyor looked for dry rot (Fresh water).
Ericson has the solution in the '80's boats. Two foot pumps for the galley sink: one for drinking water, the other either salt or icebox water (selector valve).
K2MSmith
That's interesting. I must have this configuration (82). I have two foot pedals for the galley sink. I am always using the left one (fresh water) because my water pump happens to not be working (project on the list to fix). The foot pedal on the right doesn't appear to do anything, so now I wonder if there is a "Y" valve below somewhere with the ice box drain selected (instead of salt water)
daynardi
On our '85 E32, the intake of the second foot pump has two branches. One goes to a seacock to get saltwater. The other goes to the icebox. A valve on the outlet of the icebox keeps it from flooding when the seacock is open. To empty the icebox, we close the seacock, open the icebox drain, and pump it out into the sink. After emptying the icebox, we immediately close the icebox drain so that we don't forget, then run seawater through the pump to flush out any food residue. We take care to keep the seacock closed when we aren't around.
Originally our boat had a perfectly useless shut-off valve on the gooseneck at the sink. I removed this, we now have a simple chrome gooseneck with no valve on it.
Mike Brockman
Just replace my cabin sole due to the ice box drain which was supposed to drain into the bilge had been plugged years ago and the water just drained onto the cabin sole under the icebox causing a large area of the cabin sole to dry rot.
